RE: Good Service..........Bad Service......
How about the prop adapter?? There should be an included DVD on how to properly install it! Surely you don't think that putting the two screws in the motor is any more difficult then installing the prop adapter. I think you two rocket scientist are on to something here! Heck Cal I think where you're done with all the "assembly" here you'll be able to tell all your friends that you hand crafted the motor on your plane. You've really built yourself a fine power plant there, you should be very happy with it. You didn't even get into the fact that your speed controller is not programmed for your particular setup, it still has the factory settings on it!!! There's another thing you're going to have to "build" ohhhhh the work involved here!! Please take my advise QUIT NOW BEFORE IT'S TOO LATE!!
Jim
