RCU Forums - View Single Post - vectorflight extra 66 maiden tommorrow?
Old 03-21-2005 | 05:13 PM
exeter_acres's Avatar
exeter_acres
Default RE: vectorflight extra 66 maiden tommorrow?
ORIGINAL: skypiratescotty
I have one small washer under the forward engine bolts that gives right thrust. I did'nt put in down thrust and I don't feel like it needs any when it flys. When I fly straight and level flight at 1/3 throttle and then throw her to the kitchen she just goes faster on the same line. yeeeeehaaaa!
I,m confused...is the washer between the engine and the mount or between the mount and the firewall??
if you just have one washer under the forward engine bolts (ie: between the engine and the mount on the forward bolts) than you are actually giving the plane up thrust....
to give right thrust, you would need a washer behind the engine mount or have drilled the holes in the mount with the right thrust built in.....
