@Boogie
Now I have finished the wingmod.
Oh, yes
Here you got the file
**(I should delete this)**
for the others: The wing got the size of 1624 mm and the whole for the tube should be 22mm.
Now something to explain:
1. On the top wing I must cut the main spar, because the tube was too lage for them. But I have a second main spar a little bit behind the first main spar, so I think it hold.
2. Between W1 and W2
(WB1 and WB2 too) there I filled a new piece because the bolt should be hold straight.
(so this piece is only needed on one site of the wings!)
3. The pices WS1 and WS2 could be smaller because thei must not wear the wing into one piece (the tube should do!) The piece WS3 is not needed.
I hope, it would help!
OH! If I am to delete the file, you must say! (I think ebay etc..)
