RCU Forums - View Single Post - Starting first twin
Old 03-21-2005 | 07:03 PM
kirknik
Default RE: Starting first twin
After a bit of delays I'm getting back to building. Wings are sheeted and gear and aileron servos are installed. Put em in sideways so just the arms will stick out. I extended the main gear about 2 inches for more clearance. Havent started on fitting the nose gear. Still very impressed with the kit and quality of the wood. "They just don't build em like this anymore". Thanks to Ledet and his post on scratchbuilding a Duellist. Big help and also an inspiration.
As you know, this kit takes a lot of sanding and then more sanding so notice my automatic sander that I've been working on for 9 years. Works pretty good too.
ID:	247195   Click image for larger version
ID:	247196   Click image for larger version
