Zen 50 NEED HELP.
Cut 3mm of film away on the body around they stab and do the same on the stab where it meets the body.
Make sure everything is straight and true then drop some ca in the joint to lock it into position.
Mix some 30 mine epoxy and micro ballons and dribble it into the joint. Take a wet finger and run it over the epoxy to form a fillet.
