RE: 4* 120 ailerons
The 4*120 also uses a APG guage to set up the ailerons. If you do no have a guage, se them up sighting from the side of the wing and in the middle of the top and bottom. the main thing is to set them both the same, then use a trim flight for fine adjustment.
