RE: BME Extreme 110 Carb settings?
Another note on prop slippage. If the center nut was relatively tight to begin with, if and when it slips it will usually tighten the nut, not loosen. That in itself is a pretty common occurance. If the nut was too loose initially, then coming off would be a natural ocurrance with any kind of a kick back due to excessive advance or a less than energetic flip of the prop
