RE: Material that floats
BTW, if you are going to use the alcohol get denatured alcohol. The rubbing alcohol you get at most drug stores is highly diluted with (you guessed it) water. Denatured alcohol has very little water and you can get it at some better pharmacies and at Home Depot I believe.
