RCU Forums - View Single Post - Composite ARF Impact
Old 03-23-2005 | 09:17 AM
  #460
MTK
Default RE: Impact
Rune, you are correct, the rudders are very similar in area. The Impact rudder is a little taller but narrower. The rudder design you show is the better choice over a fully sheeted, composite type, because the CG of the rudder is closer to the hinge line. This is important because inertial concerns are minimized this way, so the rudder will be far less prone to flutter. And should you decide to statically balance the rudder, it will take less weight to balance it. BTW- a statically balanced rudder will eliminate flutter, not just minimize the possibility
MattK
ORIGINAL: Rune
Hi
i made a buildt up rudder for my temptation!
weight 26 gr.
it should be almost the same size as the one for the impact i think!
