RE: GP Ultimate Bipe
Thanks Mark. That is a good idea about putting the rudder back there too if need be. I could mount it inverted somewhere between the back of the wing and tail with an access hatch to get to the servo and pull pull linkages. I would say mine will be on the nose heavy side too with the O.S. 70 surpass II that I have for it. Are the wings thick enough to mount a standard size servo on it's side so they can be hidden below the hatch with only the horn exposed or do you think I would have to mount them on their backs like most everything else is? By the way what engine do you have on yours and what was your final weight?
Rodney
