RE: Pattern Prop: 12-7 or 11-9 for YS 63?
I have a 63FZ on my Javelin II and swing a 13X6 using YS 20/20 fuel and it has plenty of authority in the air. You will want to bend up a new set of gear legs if you haven't already done so to move the wheels forward an inch or two and give you a bit more ground clearance. The stock gear will clear a 13" prop but it's awful close to the ground.
