RCU Forums - View Single Post - Inverted engines
Old 03-23-2005 | 08:19 PM
Balsa Master's Avatar
Balsa Master
Default RE: Inverted engines
if you have a clasic WWII plane with the ducting in the lower part of the cowl for airflow it will allow the header to be in more direct airflow cooling the engine better.. that and its easier to port the exaust in a scale plane if its inverted since the mufler wont be sitting clear on top of the fuse. but there right it doesent do much except leak fule if your not carful
