RCU Forums - View Single Post - --THE-- perfect setup
Old 03-24-2005 | 12:24 PM
atomicjtr's Avatar
atomicjtr
Default RE: --THE-- perfect setup
Below is how novarossi recommends breaking in motors. Some people do the "idle 2-3 tanks" before actually driving the car, but idling your car at a super rich setting is doing nothing for heat cycling the internal engine components IMO.
Engine Starting:
Fill the fuel tank and "dry-start" the engine for about
5 seconds with the carburetor in the idle position without
attaching the glow plug igniter.
This allows the fuel to
reach the engine. Then attach the glow plug igniter and
the engine should start immediately. If the engine does
not "fire-up" immediately, check the fuel line to make
sure that fuel is reaching the carburetor. If fuel is not
reaching the carburetor, remove the glow plug igniter,
cover the exhaust tailpipe and try "dry-starting" the engine
for about 3 seconds. This will build extra pressure in
the fuel line to the fuel tank causing the fuel to be pushed
to the carburetor. Attach the glow plug igniter and start
the engine. Once the engine has started, apply a small
amount of throttle and allow engine to warm up to
operating temperature.
Engine Break-in Procedure
A Nitro-powered engine requires a careful "Break-in"
procedure in order to allow the internal parts of the
engine to achieve proper operating clearances. Improper
"Break-in" will greatly diminish the performance and
life of your engine.
Enrich the fuel mixture from the factory position by
turning the main needle 1/2 a turn counter-clockwise.
Run your car, truck etc. up to 1/2 speed (at most) using
moderate acceleration. Do this for 4-5 tanks of fuel. On
the next 3 tanks of fuel, slowly increase the speed and
acceleration and start leaning the main needle setting
by turning the needle clockwise.
Maintenance:
A Novarossi engine requires little maintenance as long
as the engine does not overheat and the proper fuel and air
filters are used.
After each use:
Dry up any fuel that may remain inside the engine.
After the engine has cooled, wash it using a mixture
of petrol and 10% oil.
Clean or replace air filter if necessary.
Add a high grade "after run" oil into the engine to
avoid any internal corrosion that may occur.
