at lowest throttle plane moves forward
CyberPilot,
Most engines do idle better as they break in. It is also likely that the adjustment could be tweaked a bit. If you fly at a club, there are probably a bunch of guys there who could help you adjust it. Putting a larger diameter, lower pitch prop will probably help the engine idle at a lower speed also, simply because the longer prop acts like a bigger flywheel.
banktoturn
