RCU Forums - View Single Post - Bungee for jets??????????
Old 03-24-2005 | 04:44 PM
CTulanko's Avatar
CTulanko
Default RE: Bungee for jets??????????
Jetsetter,
The most consistent launches I have had are with one or two clicks of up elevator. When the pedal is pressed and the model begins moving, you start using your stick immediately, getting it up in the air but not too steep. Fly it straight, right at the anchor for the bungee so the line will drop off. It's about that time you can apply power, which is usually less than a second later.
Get used to the timing. I recommend you set the model on the grass next to the launcher and practice a few times...push the pedal, then throttle,... pedal, throttle...aqlmost a one-two motion and you will get the hang of it. Having enough tension to make the airplane fly is important so it is going fast enough to glide back down without power, but not so quick that you tear the hook out. Make sure it is set correctly.
Good luck,
Carl
