RCU Forums - View Single Post - First build - Sig SE started
Old 03-24-2005 | 05:47 PM
  #69
fred123
Default RE: First build - Sig SE started
Had the same problem with my left wing. Gap was not too bad, ( 1/16") [&:]so I carefully bent the Aluminum tube on that side to close it.. My gap required that the tube be bent to the rear. The bend is so slight, you can hardly see it, but it still requires that I have the tube marked put it back into the right position..Fred123
