RCU Forums - View Single Post - Tower .46 problem?
Old 03-24-2005 | 06:28 PM
Balsa Steel
Default Tower .46 problem?
Has anyone had a Tower .46 seize up on them? I had one quit on me in flight with a BANG, but was lucky enough to get it safely to the runway and noticed the spinner and prop nut were gone. I removed the engine and inspected it and saw that the con rod had let go. Looking through the exhaust port, I noticed the piston had a shiny spot on the skirt which leads me to believe that it had seized and the inertia of the prop probably pulled the con rod apart. I run Byrons 15% fuel with the synthetic/castor mix plus 1 ounce per gallon added castor. The engine wasn't running lean, nor was it a cowled installation. After one flight, a few weeks ago it had started to turn over a little tight for some reason, but after a few more flights it was fine again. Other than that, it's been a very powerful and very dependable engine. Anybody ever hear of one seizing like that?
