RCU Forums - View Single Post - Vmar Subaru bashing
Old 03-24-2005 | 09:04 PM
baddley
Default RE: Vmar Subaru bashing
Hey,
How are you guys doing. I have a VMAR Mach I skyraider. Overall i would say im fairly impressed with the arf. I know they had a bad rep in the past but i heard that have gotten better and i figured i would give them a try. I did notice a couple things though
1. The sheeting for the wing is weak and was accidently damanged in a couple spots even before the maiden.
2. Firewall next to motor needed to be reinforced.
I would have to say the balsa and would they used is somewhat weak and spots and needs to be reinforced. Im using a 46 ax. I have also seen people float these two and it worked out pretty well.
Thanks Scott
