Some corrections to various posts above. I went into Wikipedia to check out some of the materials discussed in this thread.
Acetone is Dimethyl Ketone, not MEK
. Best known use is nail polish remover
Methyl Ethyl Ketone is also caled Butanone. Primary use is in paints as a solvent as it evaporates quickly. It is a solvent and flammable.
MEKP - Methyl ethyl ketone peroxide is a high explosive in its pure state. It is an oily liquid at room temperature. There is also an acetone peroxide; however it is a white powder at room temperature. MEKP is used in a diluted form (ratio not identified) as a polyester resin catalyst.
Bottom line appears to be, if you want MEKP get the resin catalyst
Hope this helps,
John C
