ORIGINAL: PlaneInsane
Walt,
1. Code 17 - Inhibit gear switch
2. Code 56 - Mix GEAR to GEAR (5 to 5) then select CURVE for TYPE and hit ENTER
3. Hit Page and select POS1 for SNP
4. Hit Page twice
5. Now adjust using the + and - your throw for POS0
6. While holding the SNAP button adjust your throw for POS1
7. Verify in Code 75 - Servo Monitor that it works.
That's all there is to it.
I wasn't able to do it without using a curve.
Rich
Guestion #2 the above works great. Now I would like to use the gear switch we just inhibited to turn on an Ignition Cutoff(Smart-Fly) which is connected to channel 7. Thanks Walt
