RCU Forums - View Single Post - Leading and trailing edges, blunt or sharp??
Old 03-25-2005 | 12:26 PM
banktoturn
Default RE: Leading and trailing edges, blunt or sharp??
ORIGINAL: gonn for good
I' building a 35% Cap and was wondering which would be better for slow stable flight. Blunt or sharp leading and trailing edges.
Kent
Kent,
For stable flight, place your CG so that you have a decent
margin of stability. If the dihedral angle is something you're
willing to adjust, increasing the dihedral will give a bit more
stability in the roll axis, but that would not be very consistent
with the type of flight the Cap is intended for, I would think.
For slow flight, make sure that you have a low wing loading.
Within reason, the shape of the leading and trailing edges don't
have much effect on speed or stability.
banktoturn
