Sounds like your looking for the "Visible Fuselage"...
What you really need to do is to locate where the exit holes are supposed to be, per the full scale plane, and then work back wards. Once you locate the hole position you do what it takes to have your Pull/pull exit there. It's ok to have your cable running inside some nyrod tubing or similar product inside your fuse. Does this help?
