ORIGINAL: dbateman
...If you take into account also that the jet engine is not putting out alot of static thrust at lower speeds and the fact that there is no prop wash over you flying surfaces you kind of get the picture. ... Doug
Key point by dbateman. Even with instant throttle response you don't get more air moving over the surfaces until you pick up speed, which takes time.
