RCU Forums - View Single Post - Gas engines - Does Prop alignment with stroke affect vibration?
Old 09-23-2002 | 09:32 PM
Flypaper 2
Default Gas engines - Does Prop alignment with stroke affect vibration?
Where a balanced prop is mounted has no bearing on engine balance. Is the engine hard mounted,? I'f so you may have to rubber mount it. Some aerobatic planes are very lightly built and have bad vibration problems.
