RCU Forums - View Single Post - Gas engines - Does Prop alignment with stroke affect vibration?
Old 09-24-2002 | 12:20 AM
Diablo-RCU
Default Gas engines - Does Prop alignment with stroke affect vibration?
It's also critical that the engine box is rigid. Does your box have 4 solid sides? I'm not familiar with the Zinger props. Does it come with a 10mm hole or did you have to drill or ream it to 10mm? Perhaps you drilled it off-center?
