RCU Forums - View Single Post - Pull Pull cable question
Old 03-25-2005 | 08:54 PM
rctrax
Default RE: Pull Pull cable question
I have a scratch built 80" mimi-max in which I simply ran the cables back to the rudder for Pull pull control with an outlet just ahead of the fin on either side and run the cable direct from the servo to the rudder. It came out that it was not quite a straight shot but seemed to make little difference. I just used a short lenght of yellow inner rod as a ferule to run the cable through It worked very well.
