RCU Forums - View Single Post - Trainer or Other
Old 10-29-2002 | 02:34 PM
  #36
dljolly
Default Trainer or Other
If you have the area to do it, I would suggest "driving" your plane around on the ground for a bit, gives you some "backward" sense as the plane drives toward you. Also gets you used to using that left stick...
Elevator=speed, Throttle=altitude
Good luck,
Dave
