Originally posted by BMT
Why 2 Festo's when it only needs Kero you may ask? Well the festo closest is the return to the fuel tank system which allows the system to prime automatically with no operator intervention during startup.
Hi Andre,
Sounds like another neat little idea - no more pulling lines off and looking for jars to prime into, etc. So, I assume it does something like checking the engine RPM in order to decide whether the incoming fuel should be returned to the tank or injected for combustion ?
I know you are really thorough, so you're bound to have thought this all the way through - but I have to ask : what steps are taken to ensure that this doesn't cause an inadvertant flameout by having the fuel sent back through the overflow tube instead of into the engine ? (e.g if the RPM sensor dies).
Later,
Gordon
