RE: Scratch Built Ignition???
The first schematic has a high voltage alternator, which produces 200-300 volts. This makes it a bit easier to generate enough high voltage from the spark coil. The second circuit acts on pulsing 12 volts through the spark coil. I'm not sure that it would work, but maybe it does with the right coil. The way the input to the PIC is shown will work with a PIC.
