RE: bubbles?
Try using a new needle, not a pin, and poke a hole in the bubbles. This gives the trapped air an escape route. Use your sealing iron to shrink the film in the bubbled area and the film will flatten out. From a normal viewing distance the needle holes will not be visible. Some ARF's that I have seen look like pin cushions.
