Sounds like the plunger may have become stuck. Could have been a piece of crap that blew through. Do you have filters on both lines? It's important to have one between the engine and the check valve as well as one on the incoming fuel line.
Try going to
www.ysperformance.com and going through the setup instructions. It will help you get the regulator set correctly.
Good Luck!
