ORIGINAL: matus777
"First thing is, for those of you using the SWB rudder servo arm, why aren't you mounting the ball links on the bottom of the servo arm???"
Bodyworks are you using the SWB arm and if so where did you place your exit slots for the cables relative to the manual directed cutouts?
I cut the slots right where they tell you to, and yes, I am using SWB and, YES I mounted my ball links on the bottom of the arm. changing the height of the mounting location by 1/4" at the servo makes about a 1/128" difference, or less at the fuse cutout, if that's what you are worried about.
BTW, I have just the 8611 on my rudder. I am not worried about that wear so much right now, but I will ask JR if they are giving any tops out at Toledo. This servo has a TON of slop at neutral!!! With the cables plenty tight, I can move the trailing edge 1/4" in each direction! MY Hitecs, while WAY louder, don't have that slop.
