RCU Forums - View Single Post - Insight build...another wood roach.
Old 03-27-2005 | 01:50 PM
flyintexan's Avatar
flyintexan
Default RE: Insight build...another wood roach.
This morning, I predrilled the firewall for the engine mounting bolts and then glued it in place as per the offsets on the plans. After the epoxy was cured, I test fit the gear legs and took a picture (this thing is tall). Next will be to get the fuse set back over the plans, nice and sqaure, and add the rear balsa formers.
ID:	249966   Click image for larger version
