fuel backing up...
I am a new Buggie owner with a GS Storm. It has been running great untill recently. The problem I just came about is the fuel keeps flowing backward into the tank. I can get it started after I hold my finger over the pipe to prime. But, when I run the throttle wide open it bogs out until I backoff the throttle. If I gradually give it throttle it will run while picking up speed. I also noticed when I stop my buggie the fuel flows backward into the tank.Then I have to do the finger over the pipe trick to get it started after its hot. I appreciate the help..... Thanks N.[&o]
