RE: Need Help BIG TIME! 28% Extra MAJOR INTERFERANCE!!! HELP PLEASE!
#1: Are you using any extensions anywhere that have been used before?
#2: New switch or old?
#3: Is the antenna taped down anywhere?
#4: How close is the antenna to the rudder cables and/or servo extensions? Separate by as much as possible.
#5 How is the battery connection? New battery or o;d?
#6: Have you tried an electrical cleaner on the electrical contacts for all components?
#7: Are you using an old rx crystal in a new receiver?
#8: Has the transmitter ever been dropped? Check with a new crystal.
It's clearly not an engine/ignition issue since it also occurs with the engine not running.
