RCU Forums - View Single Post - Need Help BIG TIME! 28% Extra MAJOR INTERFERANCE!!! HELP PLEASE!
Old 03-27-2005 | 07:25 PM
rctom's Avatar
rctom
Default RE: Need Help BIG TIME! 28% Extra MAJOR INTERFERANCE!!! HELP PLEASE!
Absolutely you do not need PCM, that will just hide the problem. If it doesn't work with FM go no farther.
I one time had a problem like this when I used a hitec crystal in a Futaba receiver, or vice versa, I don;t remember. Check for stuff like this. There must be some common component. Unplug the switch and plug in another battery without a switch, see if that helps.
It will be solved through the process of elimination.
TF
