RE: Problems with hand launching
Before you park the plane, give these things a try.
Move the CG forward slightly.
reduce the throws from the radio using dual rate, or move the control rods a close to the center of hte hub and as far from the surfaces as possible. If that is still too much, put it away for a while.
