You had to glue hinges on an ARF???
At least they won't come loose now...
It's probably one of those questions it is hard to answer without seeing the Airplane but I'm sure if you have some movement you will be able to free the hinges enough to get full movement...
Go ahead and hook up the radio gear and just work the movable parts until they free up...
Should be fine...
Matt
