RCU Forums - View Single Post - RF interference with magneto gasser
Old 03-28-2005 | 08:35 AM
W5RA
Default RE: RF interference with magneto gasser
I have used the braided shield that I remove from coaxial cable. RG8/U is the type of cable that I get it from. If you know any amateur radio operators they could probably supply you with a piece. Most industrial electronics stores have it. You very carefully peel off the outer plastic sheath, then slip the braid off of the inner insulated wire.
W5RA
