RCU Forums - View Single Post - YS 110 Dead Stick
Old 03-28-2005 | 01:04 PM
STG's Avatar
STG
My Feedback: (26)
Default RE: YS 110 Dead Stick
Thanks for the advise. I have not moved the regulator because it seems good....
1) Plenty of smoke on transition, but no bogging. Seems plenty rich because of the smoke and seems plenty lean because transition is so fast that It can hardly be detected.
2) My initial RPM is very high. Was over 10,000 with the 16 x 6 wood! It is typically 9,900 or so with a 16x6 APC. Then it takes a few seconds for it to bog back to the high speed needle, wich I usually set at about 9,500 or so on the ground because I am thinking it will lean out a bit in the air.
Do you have any more spicific instructions that will help me determine the correct setting of the regulator?
The instructions I found don't really say how to set it or am I missing something?.....
1. Be sure that the engines has fuel lines connected per the instruction sheet supplied with the engine.
2. Open high-speed needle valve 2 turns.
3. With fuel tank filled completely and the fuel lines connect properly, prime the engine by running it at full throttle with the starter for 5 - 10 seconds. DO NOT CONNECT THE STARTING BATTERY WHILE DOING THIS.
4. Set throttle at 1/4 open. Have a helper hold the airplane if so mounted.
5. Connect starting battery and apply starter. Engine should start immediately. If it does not, check for fuel delivery and make sure the glow plug is operating properly.
6. Upon starting, allow the engine to run at 1/4 throttle for at least 30 seconds.
7. Advance throttle to full and adjust the high-speed needle to a slightly rich full power setting. When set, slowly reduce throttle to a fast idle.
8. Allow the fast idle to continue for a few seconds, then advance the throttle to full. If the transition from low to high is rich, the regulator screw should be turned clockwise. If the transition is lean, turn the screw counter-clockwise to richen. Adjustment should be made 1/4 turn at a time until you are very close then 1/8 turn for fine adjustment. DO THIS ADJUSTMENT WITH THE ENGINE STOPPED FOR SAFETY.
9. When the transition is set correctly, then reduce the throttle to full idle. If the idle speed slowly rises, screw the idle screw clockwise to richen. If the idle speed slowly drops, open the idle screw to lean. Work 1/8 turn at a time with the idle screw adjustment. Correct idle speed is 2200 to 2400 RPM. At this point the engine should be set correctly. FURTHER ADJUSTMENTS WILL BE REQUIRED AS THE ENGINE BREAKS IN.
Again thank you very much for the help.
