RE: Starting first twin
Kirk:
My trick is to use a length of bar stock, with holes drilled at the engine center to center distance. Then with the engines mounted and the crank shafts bolted to the bar I can glue the nacelles and have perfect engine alignment. No fuss, no muss.
Bill.
