RE: .40 LA engine
Thanks for responding , the engine runs horribly , and after taking a closer look I found a hair line crack in the crank shaft. Do you know where I can purschase the gasket for the backplate , or can I use the .46LA gasket instead? Both engines use the same back plate to my knowledge.
