FuryFlyer,
Here is my take on autos.
I think that learning autorotations should be a part of the training program for the flyer that has nose-in hover and FF down pat. Anything less than this can incur unnecessary crash costs.
I am not an advocate of crashing to learn autorotations and I know that many believe it is a price to pay. But, if you are trying them before you have 360 degrees of hover down and you don't know how to perfrom FF then it is pretty much an excercise in futility. Reason is that most beginners are flying non-driven tails and if the heli piros around on flare or if it doesn't weathevane cleanly for them then look out!
Currently I am shooting autos from any altitude to the left, right, and nose in. No aerobatics yet. But on a 30 size 4-5 degrees negative is a good conservative pitch. For positive pitch I try to stick with no more than 12 degrees. Any more than this and you pretty much kill the rotor speed to fast. Rememer this, try to hit the hold switch AFTER you go negative unless you are practicing hover autos. Tighten your blades up in the grips just a tad more than normal. We don't want them slinging out and striking the boom.
Here is how I learned:
1) Make a large 4' bullseye mark on the ground with florescent orange spray paint.
2) Start with the hover auto. Go into a tail-in hover from 3' and hit throttlehold. Practice experiencing landing the model without power. Lift off from the bullseye and try to land in the bullseye!! Do these over and over and over from tail-in, Left side, right side and nose-in if you are brave enough.
3) Do the same as Item 2 above but now do them from 6'. Then 12'. You will notice that a straight down auto gets pretty tuff when you get up to around 15' because you don't have much headspeed when you land because you don't have enough time to go negative before hitting the hold switch. If you can do these and you have forward flight then you got it made!
4) Now, you should be comfortable hitting the throttlehold switch in flight from all the hover autos. So, from your strongest orientation side about 75' up and 100' down wind enter FF for a couple of seconds and go negative. Hit the throttlehold switch and work at maintaining a mild nose down position with the heli maintaining your course to the target. If you hear the rotor blade get noisy then you got the disk maintaining rotor speed as air is making it up thru the blades. At about 25' bail out and kick the throttle hold off and fly out. Whewwww!!! That was exhilarating! Do this a few more times an NO more. You don't want to get spoiled on bailing out!
5) Now, do it for real! The only difference is that once you break the 25' mark you are committed! Do not bail out! Here is the key thing to remember. Work the Cyclic!!!!! If you try to stop FF with the collective you will lose what you need to flare. So, when you enter 15' you need to start to pull back elevator mildly. Don't worry about stopping ALL forward motion. This is very important. I made the mistake of trying to stop every once of forward motion and experienced a boomstike because there wasn't much inertia left on touchdown. Actually, if you are coming in fast enough in FF the elevator flare will BUILD rotorspeed. But, once you have the heli pretty much stalled from FF just let it fall and add collective. Set it down. Don't wait around. Just get the heli to under a foot and let it settle. It sounds hard but it really isn't because you have already done it with a 15' hover auto by now!
There you go. Now you can work on perfecting your timing on your next ones. There are a few other methods you can consider to make it more comfortable. One, you can get an experienced auto shooter to coach you hit the throttlehold switch for you while you concentrate on the approach. Two, you can do a straight drop auto from 75'. These are a tad harder but less disorienting. Reason they can be harder is because you don't have the luxury of that cyclic flare that builds up speed right before touchdown. Lastly, you can spend some time practicing fast low-power landings. Just use your Normal mode and modify your throttle curve to pretty much go to idle a little sooner. Or, raise your throttle percentage in throttlehold.
Hope this helps. My hand is tired. I know there are many other ways to learn but this was mine. I am no pro but I have done probably a hundred of these and only had one boomstrike. BTW, I learned them on my Venture 30 using 550mm SABs. Now, I am using my Falcon 50 SE V2 with 600mm Gammas. Much easier. But, for real leisure I drag out the ole trusty R60 with 686mm MAH blades. Man, you can hover for quite some time on the bottom with a 60 and 680s. The guys with Furys and 700+mm blades get to scratch the crotch, wipe off their brow, go get a Coke, and then land!!!!!!!!!!!!!!!!!!!!
