RE: 9C Link Issue -> Bug
We did Pmix4 first, then Pmix5 second and had all features on both mixes. We used the same channel assignments, but we also started after we cleared the memory because we'd been messing with the other mixes earlier for another customer. We usually try out our solutions on a 'clean' model memory.
The LINK or TRIM options will turn on or off, depending upon the master channel and what other mixes are set up first. If you set your mixes up the same way, but just do 4 first and 5 second, it should work. You'll still probably have to do a reset of that model, though, to get them at the defaults so that prior programming doesn't confuse the issue.
