RCU Forums - View Single Post - Great Planes Giant U-CAN-DO on tower
Old 03-29-2005 | 12:03 PM
mvigod
Banned
Default Great Planes Giant U-CAN-DO on tower
Did you guys see this yet? I've owned the big one and the 46. Now they have made the monster ucando.
http://www2.towerhobbies.com/cgi-bin...&I=LXJSX0&P=RT
Giant ucando.
Great Planes Mfg. Giant U-Can-Do 3D 1.20-1.60 ARF
A big, bold 3D aerobat!
* Wingspan: 82 in (2085mm) * Wing Area: 1772 sq in (114dm2) * Weight: 12.5-13.5 lb (5.6-6.1kg) * Wing Loading: 16.1-17.4 oz/sq ft (49-53g/dm2) * Length: 84 in (2135mm) * Requires: 2-stroke or 4-stroke 1.20-1.60 cu in (20-26cc) glow or gasoline engine, 4+ channel radio w/8 standard servos (8+ channel computerized radio with digital servos is highly recommended for maximum performance), prop
Expertly Covered in Top FliteĀ® MonoKoteĀ®
IMAA-legal
Extreme flying has never looked so good * or been so easy to sell! Intermediate-level pilots wanting an IMAA-legal size aerobat will be drawn to the Giant U-Can-Do 3D ARF: it's a great introduction into giant-scale 3D maneuvers, and a good everyday sport plane as well!
* Constructed of the finest materials * quality wood, durable fiberglass and genuine Top Flite MonoKote covering.
* For attachment ease at the field, the wing panels slide into an aluminum joiner tube, and are held in place with nylon bolts.
* Almost all servos are mounted externally, for ease of installation and strong, quick response.
* Even with its large dimensions, this model exhibits 3D maneuverability to impress and challenge even veteran aerobatic competitors!
Anxious fliers will appreciate that the Giant U-Can-Do 3D ARF can be flight-ready in just 6-8 hours.
While moderate aerobatics * including hovering * are possible with a 2-stroke or 4-stroke 1.20 engine, the sky's the limit when the Giant U-Can-Do 3D ARF is equipped with a 1.60 FX power plant like the one shown here!
The wheel pants bolt on simply and securely, and * like the cowl * are made of fiberglass and prepainted to match the trim scheme.
Large control surface deflections make for a wide range of aerobatic capability, as well as the possibility of utilizing mixing combinations for even more 3D fun!
Also available: an electric-powered U-Can-Do 3D ARF!
GPMA1271 Giant U-Can-Do 3D 1.20-1.60 ARF
Retail $479.99
Street 379.99
