RE: Trailer Slammin'
If you'll look at most trailers, the axle sits under the spring and is held in place by u-bolts. I have lowered a trailer's height by taking loose the axle and setting it above the spring - and put the u bolts back on. You have to make sure your fenders will now clear the tires - I had to re-work the fenders a little.
Just a thought.
