RE: extreme aircraft cap 232
I will let you know when I get it in the air, the sooner the better.
I still need a few more parts, which I am hopefully going to pick up at the Toledo show.
I did make a few mods to the cowl, i.e. a small cut out for the head of the Moki. Took me a while to make sure that the fit is right.
The pull pull I cannot make the wires cross as I used the straight bar that came with it. I think it will work OK, will let you know.
