RCU Forums - View Single Post - Is it possible too...
Old 03-30-2005 | 02:23 PM
2slow2matter
Default RE: Is it possible too...
ORIGINAL: wraith0078
Futaba and Hitec both use negative shift, so you'll be fine there.
This is not necessarily true. Hitec makes three different kinds of rx with respects to shift. They make a postitive shift, negative shift, and selectable shift. As long as you have either a negative shift, or selectable rx, then you will be fine. If it's selectable, make sure it's on negative shift. Always do a range check before flight. This will tell you for sure if they are compatible.
