RCU Forums - View Single Post - Will a scale main gear, with 2 inline wheels give problems on a rough, bumpy grassfield?
Old 03-30-2005 | 02:51 PM
Miguel Santana's Avatar
Miguel Santana
Default RE: Will a scale main gear, with 2 inline wheels give problems on a rough, bumpy grassfield?
2 aditional wheels generate more drag or resistance, and if the diameter of the wheels are small....the scenario is not better.- Make sure you gear bases are very strong....
Twist 90 dregrees? The best way to reduce this effect is by making sure there is not tow in or out in you mains. Make sure to have both mains very straight....
For what plane is that? I think I know but don't remember the name now
But even better solution is to.....drop a few lays of asfalt to you field ....or cut the grass...[&:]
Good luck.-
ORIGINAL: Propellars
Hi there
I was wondering if the gear would have a tendency to twist 90 degrees..
There is a spring system, making the second wheel touch the ground first, and generally carry most load, so I assume there is no problem, or?
