RE: A not so SUPER TIGRE
One added note to all ST owners.
The barrel screw that holds the barrel in place NEEDS to be lock tight. I have seen two beautiful planes get damaged (one was my p-51) from locked barrels. Let me explain, if the barrel screw vibrates loose it will slip out of the barrel grove and Lock the throttle in what every position it is in when it does.
